Hello
I'm looking for advanced grid widget and I read that it will be in 7.4
As I don't like too much to update when I have a stable release, I would like to know what means the remark "These features will be available at the end of March 2017."
Engage
It will be a separate extension that you'd import into your 7.4 system. Tentatively to come out next week.
Thanks for the detail.
I'll plan the update.
I hope than in the future these updates could be simplified (from the Composer ?) because the upgrade (Ubuntu/Postgres) by following documentation is a little bit tricky (at least for me)
It's difficult to know what should be done or not in all the steps ( "in place" or not, "Generally no need to do this ..." ...) and I cannot find the in-place upgrade for Ubuntu for
7.4.
The steps below are for migration only. For in-place upgrade, refer to In-place Upgrade to ThingWorx 7.4
(Neo4j/PostgreSQL/H2) on Ubuntu.
probably a chapter is missing ?
Document Revision History........................................................................................................................... 1
Determine Upgrade Path: In-place vs. Migration ..................................................................................... 3
Database Options: Neo4j, PostgreSQL, Microsoft SQL Server, SAP HANA, or H2 .................................... 4
Prerequisites ............................................................................................................................................. 4
Licensing Changes in 7.4 (Windows/Ubuntu) ........................................................................................... 4
Migrating to ThingWorx 7.4 (Neo4j/PostgreSQL/ MS SQL Server /H2) on Windows............................... 7
In-place Upgrade to ThingWorx 7.4 (Neo4j/PostgreSQL/MS SQL Server/H2) on Windows................... 11
Migrating to ThingWorx 7.4 (Neo4j/PostgreSQL/MS SQL Server/H2) on Ubuntu ................................. 13
Appendix A: Licensing Troubleshooting...................................................................................................... 17
Thank you for your feedback, I will reach out to the documentation team to ensure future improvement.
hello
do you know when the missing § "Upgrade to ThingWorx 7.4 (Neo4j/PostgreSQL/H2) on Ubuntu." will be added into the document ?
I do not have an ETA yet; here's the ticket number that I submitted the documentation team: PSPT-3533. Will update this thread once done.
Ok thanks a lot.
