ThingWorx 9 Active Directory communication over LDAPS fails
PGrasso
9-Granite
I am using the Directory Services configuration with LDAP:389 and it works fine but if I switch to LDAPS:636 I'm facing following error
[L: ERROR] [O: c.t.s.d.ActiveDirectoryDirectoryService] [I: ] [U: user] [S: ] [P: ] [T: https-openssl-nio-8443-exec-3] Directory Service Error: javax.net.ssl.SSLException: java.net.SocketException: Connection reset to 'Server FQDN or IP address' and 'Server Network Port' simple bind failed: 198.168.50.123:636
The simple telnet <host> <port> works fine but
Any clue?
Thanks in advance
Pier
slangley
(To:PGrasso)
Hi @PGrasso.
Here's an article that may be helpful.
--Sharon
slangley
(To:PGrasso)
Hi @PGrasso.
--Sharon
slangley
(To:slangley)
Hi @PGrasso.
If the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
