ThingWorx Analytics Trial - Lose connection to AnalyticsBuilder, Docker cont. twxfoundation stops
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello all!
If I follow the learning "Build a Predictive Analytics Model" (https://developer.thingworx.com/resources/guides/analytics-builder-quickstart/analytics-builder-setup)
First problem is that the binding of the data "analytics vibration" does not go over the progress ... status.
So after i while i click cancel, because nothing happens. Nevertheless i see the data then with status "completed". Then i go on to "Signals" an follow the steps. I can see the different sensor names s1_fb1 ... but no values on the right. It´s not loading. At this point im loosing every time the connection to thingworxbuilder and also to composer.
The builder does not react any more if i switch for example to settings...
Status message:
Could not load "TW_ML_Signals_Horizontal_v1". Reason: 200 -
If i check docker container ls status i see that twxfoundation is not there anymore. I need to restart TWA but i can not go further than the problem described above in the "Signal " configuration...
Please find the logs
- Docker Service log
- Status / Debug AnalyticsBuilder
- Status messages snap
Thank you very much
- Labels:
Analytics
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi
It is always difficult to tell how much you need as it depends very much on the dataset size/data.
However for the vibration one, I would think between 6Gb to 8 Gb should allow you to run it.
Kind regards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi
When the problem occurs, could you execute docker container ls -a instead of just docker container ls.
That should give the exit code of twxfoundation container, and possibly give some clues.
Kind regards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello!
While the problem occurs i am not able to reach docker with commands at all. Powershell is waiting for reply...
Furthermore i am not able to stop thingworxanalytics over "analytics trial edition stop"
I added some screenshots .
Can you read something out of the docker service file?
Thank you and best regards
Mathias
- Tags:
- troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Mathias
Thanks for the new data.
In the first zip you attached, there were one screenshot of docker container ls with no twxfoundation in the output.
Can you be in the same situation but execute docker container ls -a instead ?
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Mathias
yes this helps.
The Exited(137) for docker means out of memory.
You need to allocate more memory to the docker daemon.
The following article should help: https://www.ptc.com/en/support/article?n=CS275881
Kind regards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hey! Okay thank you. My local machine has 8gb memory. I run docker with 4gb but as it shows this was not enough.
How much does docker need? Windows just accepting 4.3 gb in my case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi
Kind regards
Christophe
