Hello Everyone,
We are facing an issue while viewing Mashup in Runtime or Preview it is giving
error but the Composer is working properly.
If anyone has faced this issue or knows what could be the reason for this, please provide the information.
Thank You
Hi @PG_CG,
Are you using Navigate trying to view a mashup contains cross-domain contents?
If that's the case, below documents might be relevant for you.
https://www.ptc.com/en/support/article/cs333587
https://www.ptc.com/en/support/article/CS318637
