i installed ThingWorx Anlaytics Trial version.
Unfortunately it does not run properly because i am not able to see the AnalyticsThings or can do the AnalyticsServer Configuration. Please see my screenshots and log files of the installation.
Thanks for your help!
Thank you so much for confirmation. Request you to open a new thread for new query. Please mark accept as solution for this thread so that we can close this thread.
Thanks in Advance.
Regards- Mohit
Could you please check in services tab if all the services are running or not?
Mohit
Yes i am using Windows.
I checked my services and i can not see any service related to ThingWorx ...
I am currently running the composer over "anaylitcs trial start" succesfully .
Could you please have a look at this article.
Do let me know in case of any question.
Regards- Mohit
Hello!
In my ThingWorxAnalyticsServer folder i do not have a "data" folder.
My application key is valid and correct. I created also a new one with admin user and changed it in the config files. No improvement.
Article CS271819 (https://www.ptc.com/en/support/article?n=CS271819):
Can you tell me also where i can find those log files?
Can you please check the attached logs from my ThingWorx Monitor
Thank you very much!
Hello!
Please find my Analytics Logs attached.
I have some progress here. Our internal firewall blocked the docker ip adress. Now i ´am able to see the Analytics Things in ThingWorx !
Now i wanted to do this learning:
https://developer.thingworx.com/resources/guides/analytics-builder-quickstart/signals-and-profiles
And here i am heading the next problem. Every time i set up my data model and configure my "Signal" in AnalyticsBuilder i´m loosing connection in the AnalyticsBuilder and the attached "Status Message" appears showing:
"Could not load "TW _ML_Landing_Page_v1". Reason: 0 -
"Could not load "TW_ML_Signals_Horizontal_v1". Reason: 0 -
"Could not load "TW_ML_Profiles_Horizontal_v1". Reason: 0 -
One strange thing is that when i upload the vibration data it says "...progress " but never finish but If i click cancel after some time my data is uploaded
Thank you!
But the
Thanks in Advance.
Regards- Mohit
