ThingWorx Visual SDK access
FredSilva92
Hello PTC Community!
I found out this API related with widgets development:
http://support.ptc.com/help/thingworx_hc/visual_sdk/
I trying to install it on my dependencies with npm, but i'm getting the below error:
I'm wondering what kind of licences that i need to have access to this repository.
Thanks a lot.
CharlesJi
(To:FredSilva92)
Hi @FredSilva92, seems like you are trying to get the codes from the remote repository. You should download the file first and install it locally via the command.
Check here for more details:
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-Web-Component-Development-Guidelines/m-p/681601#M47138
CharlesJi
(To:FredSilva92)
FredSilva92
(To:CharlesJi)
Hi @CharlesJi,
Thank you for our suggestion, i will try it.
slangley
(To:CharlesJi)
Hi @FredSilva92.
If the response from @CharlesJi answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
