ThingWorx data hygiene
Is there any ThingWorx built-in API or services for data hygiene?
Clear. As stated before, before adding training data into ThingWorx Analytics, we usually use the external tools we're familiar with (Jupyter Notebook etc).
You can use the many many snippets available in ThingWorx services (see below) to perform this type of cleaning, but they are not at the level of speed that tools like that offer. That does not mean they don't work - just that people are far more familiar in ML land with using stuff like Jupyter,
Snippets available in any service editor:
One last thing: typically what we see is the ETL process that takes most time, for example, what I saw is it takes 60-80% of the total time spent on Analytics.
Using really ThingWorx Analytics is usually a very easy process which takes much much less (just load the training dataset, set your goal and let the system crunch, rinse and repeat whenever needed).
Don't be shy on not using external ETL tools to process/clean your data. As I said, ThingWorx Analytics itself is not intended on being a replacement for an ETL tool.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
