Will the thingworx foundation not run without the license installed? The ThingWorx foundation is installed in our server but we have not applied the license. Whenever we start the tomcat and try to run without license, the tomcat automatically stops. Is there a dependency of license for apache and thingworx foundation to run? Is it not possible to up the thingworx foundation to run as unlicensed version and import entities and apply the license later?
Thanks & Regards,
Shalini V.
You need to check the logs to determine the cause of the failure. Check the ApplicationLog.log located in \ThingworxStorage\logs. If no logs exist there, check the <tomcat_home>\logs. Some likely causes:
A ThingWorx licensing issue would not prevent Tomcat from running. If this is a new installation, ThingWorx should start up in limited mode until the license is applied.
Please let us know if you have further issues.
Regards.
--Sharon
Regards.
--Sharon
If the previous response allowed you to resolve your issue, please mark it as the Accepted Solution for the benefit of others in the community. If you are still having issues, please provide the ThingWorx and Tomcat logs for our review.
Regards.
--Sharon
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
