I want to bind the Database record in a ThingWorx grid with "Column span" as shown below. I am using the ThingWorx version 9.3.8-b1504. Kindly suggest me with the steps and which Grid should I use for this cause?
Hi @SKannapiran
Look at the below article, and let us know if it will work in your use case.
Hi @Surya_Tiwari ,
In my above screen shot, i am expecting a comparison functionality to be implemented in the ThingWorx Grid (i.e.., Column Span). Your reference link is to Change the "Grid" columns dynamically in ThingWorx.
