We have 2 questions regarding the logs in ThingWorx.
2. How to break the thingworx stderr & stdout file based on date or size? Because right now everyday logs are logged in the same file unless it the tomcat service is restarted.
Thanks in advance,
ShaliniV
Hi @svisveswaraiya.
You're actually referring to the logs located in <tomcat_home>\logs, correct? Here is a link to an article that may be helpful for limiting the size of the logs. For limiting the content of the messages, there is a level option that may allow you to tweak what gets written:
Example: <File Handler>.java.util.logging.FileHandler.level = FINE
You can refer to this page for the logging levels. This will need to be applied to any of the file handlers you wish to adjust.
--Sharon
Hi @svisveswaraiya.
--Sharon
