Thingworx 7.0.1 error while importing Windchill Extension 1.2.1-01
kmorales
2-Guest
Hello Community,
While trying to import the ptc-windchill-extension-1.2.1-01.zip extension, I'm getting the following error:
     The extension 'ptc-creo-view-extension' version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.
Appreciate any guidance.
Best regards,
Keiner
Here the error.log Outcome as reference:
2016-04-14 15:28:10.311-0600 [L: ERROR] [O: E.c.t.w.ExtensionPackageUploader] [I: ] [U: kmorales] [S: ] [T: http-nio-443-exec-6] [context: Extension Exception][message: The extension  'ptc-creo-view-extension'  version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.] com.thingworx.extensibility.ExtensibilityException: The extension  'ptc-creo-view-extension'  version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.
        at com.thingworx.extensibility.utils.ExtensionPackageUtilities.loadExtensionMetadata(ExtensionPackageUtilities.java:868) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.extensibility.utils.ExtensionPackageUtilities.extractExtensionPackages(ExtensionPackageUtilities.java:724) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.webservices.ExtensionPackageUploader.beginImport(ExtensionPackageUploader.java:174) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.webservices.ExtensionPackageUploader.service(ExtensionPackageUploader.java:103) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [servlet-api.jar:na]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) [catalina.jar:8.0.24]
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) [catalina.jar:8.0.24]
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.0.24]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) [catalina.jar:8.0.24]
        at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:94) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:21) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:343) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:143) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:31) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:118) [thingworx-platform-common-7.0.1-b482.jar:na]
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [catalina.jar:8.0.24]
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142) [catalina.jar:8.0.24]
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [catalina.jar:8.0.24]
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:617) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [catalina.jar:8.0.24]
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518) [catalina.jar:8.0.24]
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091) [tomcat-coyote.jar:8.0.24]
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668) [tomcat-coyote.jar:8.0.24]
1 ACCEPTED SOLUTION
brue
1-Newbie
(To:kmorales)
As the message states, that extension's version does not match the major.minor.patch pattern. Remove the 38 from the packageVersion property in the extension's metadata.xml and you'll get past that error message.
4 REPLIES 4
brue
1-Newbie
(To:kmorales)
Thanks Brian. It worked perfectly.
lcampion
1-Newbie
(To:brue)
Same problem, same solution. Thx a lot.
Just FYI - Thingworx released new version of Windchill Extension whick works fine with Thingworx 7.0 and 7.1 (the issue is fixed).
