Thingworx 7.4 MSSQL Install Errors
SOLVED
Re: Thingworx 7.4 MSSQL Install Errors
     If you did restart the SQL service after you did the changes that Matthew suggested and it still doesn't work, just change the status of the TCP/IP protocol from the SQL Server Configuration Manager from Disabled to Enabled, restart the service again and try. For me it worked like that
its this solution for ThingWorx-Platform-Mssql-8-1-0? I have same error message?
Thank you Matthew, you saved my day!!!
