Thingworx 8.4.0 Active Edits
agondek
How does one close an "Active Edit" using the New Composer in TW 8.4? In the Old Composer, you could close an active edit by saving an entity and then closing the tab. In the New Composer, closing the tab does not close your edit. In order to close the edit, do you have to cancel the edit session and then close the tab?
If yes, that seems like an unnecessary extra click.
PaiChung
22-Sapphire I
(To:agondek)
I believe the Cancel Edit is necessary because the - symbol is a minimize not necessarily a close.
agondek
(To:PaiChung)
I was referencing this cancel button
It doesn't seem to close the edit, however, it warns that you will lose your changes if you close this way.
PaiChung
22-Sapphire I
(To:agondek)
I thought the composer shows a * symbol next to those items that are edited and not yet saved.
So it may be an inconsistency in the logic in composer if it warns you even if there isn't a * symbol
