Hi - I need some help with retrieving a proof of concept that was built on the trial version. The license for the trial has since expired and I am unable to login and extract the files. Is there a way to extract the solution that was built or a possibility for a temp license that I could use to get the files?
Hello @hgrewal,
As I have helped you offline with this issue (provided 1day temporary license that allows you to collect all necessary data from your TWX Server), could you please mark this as delivered solution to close this thread in the Community?
Thanks!
Vanessa
Hello hgrewal,
I have just sent a message to you to assist you with this topic.
Thanks!
Vanessa
Hello @hgrewal,
Thanks!
Vanessa
