Thingworx 8.5/9.0 - AD Directory Service
hkwan
7-Bedrock
Hello All,
1.I'm new to AD.
2.I've setup AD on a Win2012r2
3.I've installed TWX8.5/Win2016, and import AD - Directory Service, based on https://developer.thingworx.com/en/resources/guides/enabling-ldap-authentication-thingworx
4.I'm unable to find the settings in AD, which i can use to configure the TWX - AD - Directory Service - configuration page.
Pls advise. Thanks
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:hkwan)
Looks like you are doing everything right.
Not sure if you've check the helpcenter
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FComposer%2FSecur...
PaiChung
22-Sapphire I
(To:hkwan)
hkwan
7-Bedrock
(To:PaiChung)
Dear Pai Chung,
1.Appreciate your prompt reply.
2.Have read the user guide, which you're provided. I realize that my AD configuration is different from the one in the user guide. Pls help to take a look.
3.Have setup Windows AD on another computer. Plan to test the TWX - AD configuration w/ the installed Windows AD. However, was stuck as i can't find the corresponding settings to match. See, below, w/ the AD. Would you please show me where i can the settings in AD?
4.I've tested the AD. It works okay, as i'm able to login as a domain user from another computer.
