I have old popups (static, and made with TW 8.3) that works fine on 8.5, that can be moved.
But if I create a new pupop as responsive (static is shown as legacy so I prefer to not use it), I enable title bar, I open it as "popup" (not modal popup) it opens but the title bar cannot be clicked and so cannot be moved ...
What I'm missing ?
Sorry, I found what I was missing ... there is:
- TitleBar property inside the mashup editor
- PopupTitle property on the Navigation widget that opens the popup
By using PopupTitle the popup can be moved
TitleBar is probably used only when the mashup is a gadget
so .. fixed by myself
Hello @iguerra
As the issue is resolved can you please mark it as resolved for benefit to others .
Om Dukiya
