Frame Layout widget didn't work in thingworx 8.5
Anyone has similar widget recommendation or any suggestion on building overlay layouts instead of frame Layout widget?
Hi @hkumar-41.
Apologies for the delay.
Are you referring to the Frame Layout widget that used to be available on the Marketplace? Unfortunately, that widget is no longer available.
We would recommend either posting this as an idea on the ThingWorx Ideas site, which would allow others to vote on it, or writing your own extension. Here is a document to help with that.
Regards.
--Sharon
Hi @hkumar-41.
Regards.
--Sharon
