Is Thingworx 9.1.7 stable enough and without bugs to install in a customer environment?
Sadagopan P
Hi @psskps.
All publicly available releases are considered stable. If you are trying to determine the best version to install, however, it's always a good idea to evaluate the latest version due to the bug fixes, feature improvements, etc. The latest releases will also be covered under support for a longer period of time.
Part of the decision, however, will need to be driven by other PTC products you may be running. You can use the Release Advisor to confirm compatibility between product versions.
You can also check the release notes for each given release to determine what fixes are included and what known issues exist for a given release.
--Sharon
The following fixed and known issues are part of ThingWorx Platform 9.1.7: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Release_Notes/FixedIssues/Fixed_Issues_in_ThingWorx_Platform_9.1.7.html
Hi @psskps.
--Sharon
