I am trying to install Thingworx 9.1 Foundation Installer with Postgresql on Fedora 34. It is failing at 96% every time. Kindly guide
Error in bitlocker log as below
Also attached all log files. Kindly help.
Thanks for reaching out to us. can you check below article and let us know if this works.
https://www.ptc.com/en/support/article/CS329897
Mohit
JAVA and POSTGRESQL path are correct but still not installing. Tried all options.
Fedora 34 may not been tested in TWX installation, it's not in system supported list.
Which open source linux OS and version is currently supported by Thingworx 9.1?
Open source OS is not mentioned in the list
If you feel @zyuan1 response is appropriate on your question, please mark this thread accept as solution for the benefit of other community users.
Mohit
