Are there any contraindications/issues/suggestions using the ThingWorx Foundation Installer for Windows if the Window Server OS is a Datacenter version?
Thanks in advance
Pier
There are no known issues or suggestions when installing Thingworx 9.2 on windows server 2016 datacenter version. The only thing to take care is it should be 64 bit.
