Thingworx 9.6.0 Compatibility.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi All,
Is Thingworx 9.6 compatible with postgresql version 15 or can we install with that.
And i should have to go with lower versions of postgre.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @Hrishabh.Sharma ,
Hope you are doing well!
Pls check the SS for your reference:
Thanks and have a good day!
Bhawna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Bhawna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Getting this error during installation.
do you have any idea about this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Can you pls share the installation logs ? Although, I would recommend you to log a case so that you can get better assistance.
Bhawna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Where? we can check the the installation logs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm trying Postresql 15.8, and This is not on your list.
It would be works or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
In most of the scenarios, it does work. However, It is not recommended to use the lower versions.
Bhawna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Okay Bhawna.
