Dear Sir/Madam,
1.I'm new to thingworx. Would like to an extension which will trigger an event when it detects a change in SQL server - table (similar to the SQL trigger). I guess i would like to program the extension using Thingworx .NET SDK.
2.I've searched Thingworx documentation w/o much success.
3.I've several questions.
(a).Is my solution valid? If not, any alternatives?
(b).Where can i download the Thingworx .NET SDK s/w & documentation?
(c).Is Thingworx .NET SDK supported on Thingworx 9.x?
"ThingWorx Edge .NET SDK":
Dear Vladimir,
1.Thanks. Will read the documentation.
2.The client has a requirement:
(a).When there is a change in a SQL Server -> Database -> Table, it'll trigger a Thingworx 9.x.
(b).I surmise i would need to program extension which will trigger an event when it detects a change in SQL server - table (similar to the SQL trigger).
(c).Am i on the right track?
