Hello Team,
We are doing some tests with Thingworx Analytics 9 and have the following questions:
1. Is there any better guide or best practices document on how to use the Thingworx Analytics APIs?
2. We also ran a test where we created a model training job on analytics server thru the API, we have confirmed the job completion using the API, but we can´t see the model in the Analytics Builder UI – anything we need to include in the API so we can see the model in the Analytics Builder UI?
3. Do we have any examples of Thingworx Analytics API calls and use cases?
Tks,
Chris
I believe you also opened a case for this inquiry, and I have reached out to you on that case.
I will copy and paste the info I sent you in the email for the case here as well:
Please let me know if this provides the requested info by marking this comment as "Solution Accepted"
Neel
