Thingworx Analytics Predictive Analytics Model Guide
SOLVED
Highlighted
Guest
Hi all,
I started evaluating Thingworx and already added a mqtt thing and a mashup to my hosted trail version. Now I wanted to test the "Build a Predictive Analytics Model" guide, but I can not connect to the analytics server, when I try to select the analyticsServer_Thing in the analytics Gateway field there are no search results, I can also not find any "gateway" thing in my version. How can I solve this problem?
Kos
1 ACCEPTED SOLUTION
Highlighted
Re: Thingworx Analytics Predictive Analytics Model Guide
Greetings,
Yes, the Developer Portal 30-day hosted trial includes both ThingWorx Foundation and ThingWorx Analytics.
Typically, the hosted Analytics server not connecting to the hosted Foundation server is caused by one of three issues:
1) Configuration Service hasn't been run
2) Session Variables haven't been added
3) The Application Key expiration-date hasn't been extended
These topics are covered on this page of the guide:
https://developer.thingworx.com/resources/guides/analytics-builder-quickstart/analytics-builder-setu...
Please recheck each of these items.
In particular, you may wish to explicitly delete the TW_ML_Session_Variables (if it is pre-existing), Save, re-add TW_ML_Session_Variables, and then Save again.
If none of these steps allow Analytics to connect to Foundation, please let us know.
In addition, you may wish to try the 120-day, self-hosted Analytics Trial Edition (ATE) found here:
https://developer.thingworx.com/resources/downloads/analytics-trial-edition
ATE spins up both TWX Foundation and Analytics in Docker VMs on your local PC. If the above steps don't work, then you should be able to explore your requested Analytics Builder guide via ATE while we troubleshoot the hosted server.
Thank you,
Jason
5 REPLIES 5
Highlighted
Hi
Can you confirm if you have installed an ThingWorx Analytics Server ?
If yes, what version is it, and what version of ThingWorx platform are you using ?
Do you see an AnalyticsServer_Thing in Composer ?
if yes, go in properties , what is the value for isConnected ?
Christophe
Hi Christophe,
Sorry for my late reply. I don't know if the analytics version is really installed, but the thingworx developer page says "The hosted trial includes Foundation, Utilities and Analytics so you can explore the platform capabilities for 30 days using our Guides. " The version of Thingworx is 8.2. No I can't find a AnalyticsServer_Thing in the composer.
Best regards
Highlighted
Hi
I am checking with the hosting team as you should see the AnalyticsServer things, so there is possibly something wrong on your instance.
Kind regards
Christophe
Highlighted
Greetings,
Thank you,
Jason
Highlighted
Kos,
Sorry for the issues that you are experiencing.  There should definitely be a Thing called "AnalyticsServer_Thing" (see attached screenshot).  If you do not see this, the easiest thing to do is to have you export your work and we will provision you a new server.  Please reach out to the Developer Portal team (TWX-DevZoneHelp@ptc.com) and we can coordinate directly.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
