I had download version 8.2.0 r2 but there is installation issue on ThingPredictor.
Where can I download Thingworx Analytics Trial Edition 8.2.0 r3?
Thanks in advanced.
Hi
Just to inform you that the link has been updated.
However as I mentioned earlier you need to download the Analytics Trial Edition (ATE) NOT the ThingWorx Trial Edition (TTE)
Kind regards
Christophe
Hi @lchan1
You should be able to get it from https://developer.thingworx.com/resources/downloads . The version has been updated since.
Kind regards
Christophe
I download again the file and unzip.
The unzip file is still ThingWorxTrialEdition-8.2.0-r2-windows-installer.exe
Hi
Thank you for this.
I am checking with the DevZone team how is hosting the download to know what is happening.
A note though, the screenshot you attached shows that you have downloaded the ThingWorx Trial Edition. In order to use ThingPredictor you need to use ThingWorx Analytics Trial Edition. which can be downloaded from the same place but under ThingWorx Analytics, not the complete bundle.
However I did download just now and it does show r2 and not r3, this is why I have contacted the DevZone team.
Will let you know
Kind rgeards
Christophe
Thanks!
Awaiting the updated download link for TTE R3.
Best Regards
Hi
Kind regards
Christophe
Downloaded the ATE R3 and install without problem.
Thanks a lot.
