Hi Community,
Recently my MS Sql server was poping message that it's login password expired and I need to update it. When I updated my password, Thingworx is not starting and giving following error :
Error : [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] *** CRITICAL ERROR ON STARTUP: Connections could not be acquired from the underlying database!
Can anyone suggest how I can troubleshoot this error and avoid such errors in future. Thanks in advance.
Attaching Application log for reference.
Sid
Hi @Siddharth_Jhs.
Basically, when you change the password for the ThingWorx user in SQL Server, you need to update the \ThingworxPlatform\platform-settings.json file with the new password. If it was encrypted just replace with the new password in clear text, then refer to this page of the Help Center for re-encrypting it.
The links to the articles provided by Vladimir contain more details.
--Sharon
Articles:
Hi @Siddharth_Jhs.
--Sharon
Thanks @slangley this is the information I was looking for. Alternatevily, I tried resetting my server login password to the original one which was stored as encrypted text in platform-settings.json file worked for me.
