Thingworx Directory Services - Issue In Invoking AD Services From Other Things
mdeshpande-2
7-Bedrock
I have this scenario wherein I have to configure the Thingworx Directory Service  settings programmatically.
So, when a user specifies a setting from the UI, I need to update it into the respective configuration table on the Directory service.
However, I need to call these services from inside another thing.
When I invoked the services from another thing, all services from my Directory Service entity errored out with -  Error executing service <serviceName>. Message :: ReferenceError: "DirectoryServices" is not defined.
For example even the GetConfigurationTables services gives an error -
// result: INFOTABLE dataShape: "EntityList"
var result = DirectoryServices["Test.ActiveDirectory"].GetConfigurationTables();
Is this the default working for directory services in Thingworx or is there anything I am missing ?
Any help is highly appreciated.
Thanks!
Note: Thingworx version is 8.5.6.
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:mdeshpande-2)
If I'm not mistaken you are running into a bug unfortunately.
https://www.ptc.com/en/support/article/CS303447?&language=en&posno=1&q=%22DirectoryServices%22%20is%20not%20defined.&source=search
As a work around that you can potentially use is to invoke it using the content loader functions (REST call)
However this bug is fixed in 9.0.x ? so I recommend using a more recent version of Thingworx.
5 REPLIES 5
PaiChung
22-Sapphire I
(To:mdeshpande-2)
I don't have an instance with AD set up to check this but check the following
<server>/Thingworx/DirectoryServices/Test.ActiveDirectory
And then go into Service Definitions to see if there are any.
Although I imagine you got the service using the 'Browse'?
Could you at all be running into any permissions issues?
Hi Pai,
I checked and yes, I get all the service definitions listed for the Active Directory instance.
If I execute the service from the Active Directory Entity directly, then it works.
The problem is only when I try to execute the services from inside another thing.
The user I am using is a member of Administrators group.
PaiChung
22-Sapphire I
(To:mdeshpande-2)
Hi Pai,
Yes, seems to be a bug.
I tried the work-around and used the REST API method with Content Loader functions.
I can get the configuration tables values using both the GetConfigurationTable(s) services.
However if I want to set the configuration table values, I am running into issues.
Tried using Postman , details as below -
Service- SetConfigurationTable / SetConfigurationTableRows
Input - Sent a body as a JSON having three input params as - tableName, persistent and configurationTable / values (depending on the service used).
Method type - Post
Authentication - Basic Authentication (Administrator user)
The configurationTable / values is in itself an infotable type, so the value of this input parameter I sent as a JSON representation of an infotable (including the datashape definition and the rows array)
I am having problems executing these rest calls, it gives 400 (Bad Request) (SetConfigurationTable) or 403 (Forbidden) (SetConfigurationTableRows)
Am I missing any step/ maybe doing something wrong ?
PaiChung
22-Sapphire I
(To:mdeshpande-2)
For the set ... that might be hard since it is of type infotable.
I would try it using the PostJSON in Thingworx so you at least you can do a get of the configuration table, edit it and then post it.
