Thingworx EMS Java SDK connection problem
Benzar
Hello.
I'm trying to connect to my localhost:8080/Thingworx   Composer.
I'm executing a tutorial jar file.
The Error message I'm getting is this.
java -Duser.country=US -Duser.language=en -jar TruckSimulator.jar
15:00:40.405 [main] INFO  c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
Starting the stuff
URL: ws://http://127.0.0.1:8080/Thingworx/WS
AppKey: bde92937-8a45-4089-ae41-5dde64482dfb
15:00:40.460 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
15:00:40.462 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 16
15:00:40.468 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.nio.ch.DirectBuffer.cleaner(): unavailable
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by io.netty.util.internal.PlatformDependent0 (file:/C:/Users/Ryong/Documents/MicroServer_Java/TruckSimulator.jar) to field java.nio.Buffer.address
WARNING: Please consider reporting this to the maintainers of io.netty.util.internal.PlatformDependent0
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
15:00:40.470 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: unavailable
15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 8
15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: unavailable
15:00:40.483 [main] DEBUG i.n.util.internal.PlatformDependent - maxDirectMemory: 4265607168 bytes (maybe)
15:00:40.483 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
15:00:40.484 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
15:00:40.484 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes.  Please check the configuration for better performance.
15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\Ryong\AppData\Local\Temp (java.io.tmpdir)
15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: true
15:00:40.485 [main] INFO  i.n.util.internal.PlatformDependent - Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system unstability.
15:00:40.495 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
15:00:40.495 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
15:00:40.715 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 8
15:00:40.715 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 8
15:00:40.717 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
15:00:40.721 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
15:00:40.722 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
15:00:40.722 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
15:00:40.725 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
15:00:40.726 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
15:00:40.730 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
15:00:40.731 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
15:00:40.731 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheCleanupInterval: 5000 ms
15:00:40.738 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
15:00:40.742 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
15:00:40.743 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
15:00:40.743 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
15:00:40.744 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
15:00:43.024 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://http://127.0.0.1:8080/Thingworx/WS] failed : null
15:00:43.024 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
I've configured my TrainingConfig.json file like this.
    "ServerLocation": "http://127.0.0.1",
    "Port": 8080,
    "AppKey": "xxxx-xxx-xxx-xxxxx(my app key)",
    "Security": false,
    "RemoteRepo": "/ThingworxRemoteRepository"
Can someone tell me how to solve this problem?
Thanks.
0 REPLIES 0
