Hello Together,
I'm facing the following issue when install Thingworx Extension with Eclipse.
Cannot complete the install because one or more required items could not be found.
Software being installed: ThingWorx Extension Builder 7.2.0.201608021836 (com.thingworx.eclipse.extension.feature.feature.group 7.2.0.201608021836)
Missing requirement: ThingWorx Extension Development Environment 7.2.0.201608021836 (com.thingworx.eclipse.extension.ui 7.2.0.201608021836) requires 'osgi.bundle; org.eclipse.wst.server.ui 1.5.100' but it could not be found
Cannot satisfy dependency:
From: ThingWorx Extension Builder 7.2.0.201608021836 (com.thingworx.eclipse.extension.feature.feature.group 7.2.0.201608021836)
To: org.eclipse.equinox.p2.iu; com.thingworx.eclipse.extension.ui [7.2.0.201608021836,7.2.0.201608021836]
Eclipse IDE Version:
Eclipse IDE for Java Developers
Version: 2019-09 R (4.13.0)
Build id: 20190917-1200
hi,
i think it might be missing required eclipse version 4.5 or newer
follow the article for further clarifications
hi,
Thank i needed the Enterprice Java Eclipse
