As per this thread - same issue
I am facing similar issue for testing flow execution.
To execute this flow i have configured alert as trigger from thingworx, but even after generating alert on thing I am not able to see any logs it flow.
I have tried to add logger in flow, but still not able to see any logs.
Could you please provide stepwise procedure for same?
You can refer to the below sample to test it. Of course, you can strip the tasks/nodes to make it simple.
