Hi Team,
We want to know the existing font name which is being used in the Thingworx 8.0.3
What is the way out to find the same.
Another issue is we want to have our own custom font to be used for Labels captions. what is the way out to do so.
We have tried to download the exiting extension "FontLabel" from Market place which also did not worked.
Regards
Vidyadhar Dhumal
Hi Vidyadhar Dhumal,
I have tested Font Labeling Widget with TW 7.3 it is working fine now. You can download from ThingWorx IoT Marketplace and try to change a font style as mention in reference document.
Thanks & Regards,
Sathishkumar C
I do not know the font name. But if you have issues, perhaps 8.2 with the new CSS support might be supporting changing font?
Thanks & Regards,
Sathishkumar C
