There has been error.
This version of thingworx foundation already installed.
If I'm trying to install some other version of Thingworx...
How to resolve this issue and install Thingworx Foundation?
Followed the article.. Following a failed attempt to install ThingWorx 8.5 Foundation/Flow, subsequent attempts result in error "Previous installation of ThingWorx-Foundation is found"
and deleted the Thingworx service using folowing command and installed.
sc delete ThingWorx-Foundation
Have you checked the ThingWorx Platform folder? Could be some files have not been removed from there yet
Have you also checked the Database schema ? maybe creating a new schema which different from the first schema of the ThingWorx Model DB ?
Somehow started the installer...
But in between installation fails... Getting following error. Attached logs also/
Hi @Sathishkumar_C,
You may refer to the following article to see if it helps:
Check the user profile folder in Windows for the user that originally ran the install. Look for a folder called .ptc_ccif. For example: C:\Users\Administrator\.ptc_ccif. Since you're planning to do a fresh install, you can safely remove this folder.
--Sharon
@Sathishkumar_C ,
I faced this before,
Either older version Files still exist on the system, or any service of an older version is running in the system. Need to delete the files and stop the services if they are running.
Hello @Sathishkumar_C
I would like to suggest you to open a new case with IT Support team( share the case number on this thread) or pls let me know I can open on your behalf .
Kindly let me know.
Bhawna
