How can set the same TitleBarText mashup property for a Gadget to be the same as the populated when adding a gadget to a group on a Dashboard.
In the gadget mashup I am able to set the TitleBarText base on a service, but the "Add Gadget" pop up in the gadget title has "unknown".
R Resources["DashboardFunctions"].RenameDashboardItem has the option to set a name but i should specify the dashboardID and the groupID, nevertheless, I want to be able to set it at run time for the selected and group.
Valeria Gloria Guevara Perez: Just wanted to check on this post is this still open or you got the resolution since has been marked as Assumed Answer .
-Durgesh
You will need to set it from the library.
