Thingworx HA
SOLVED
Highlighted
vi1
Amethyst
Thingworx HA
I am configuring HA for Thingworx.
I have installed Zookeeper 3.5.5 and configured Zoo.cfg.Also created myid file.
After that, i am trying to start Zookeeper and unable to start Zookeeper server. I am getting the error. I have attached screenshot what i am getting error.Could you please help on that.
Latha
1 ACCEPTED SOLUTION
Re: Thingworx HA
I've just understood -- your myid has ".txt" extension! Remove this extension, it should be called just "myid", then it will work. Keep double slashes though.
/ Constantine
15 REPLIES 15
Re: Thingworx HA
Hi @vi1.
You might try checking stackoverflow for resolving Zookeeper start up issues.  If that doesn't help, you'll need to Google it for other possibilities.
--Sharon
Re: Thingworx HA
Can you confirm that you have a directory "apache-zookeeper-3.5.5" under c:\zookeeper?
/ Constantine
Re: Thingworx HA
Yes, I have created folder "apache-zookeeper-3.5.5" under c:\Zookeeper. please find the attached screenshot.
Thank You
Re: Thingworx HA
And I assume you have complete Zookeeper installation inside this folder? Can you take another screenshot of its content, please?
Re: Thingworx HA
Thank you.
Here attaching complete folder content screenshot.
Latha
Re: Thingworx HA
You downloaded Zookeeper's source code instead of the binary distribution. Go back to Downloads and get the one with "-bin" in its name, e.g. "apache-zookeeper-3.5.5-bin.tar.gz".
Re: Thingworx HA
Thank you for information.
I have downloaded bin folder and copied. Still unable to start the server and getting the errors.
Please refer the attached screenshot.
Vidyullatha
Re: Thingworx HA
Also, attached conf folder content screenshot.
Re: Thingworx HA
I see on your screenshot an error message, which says that your "conf/zoo.cfg" file is invalid, so I guess you need to take a look at it. Here's explained how to configure it on Linux: https://www.ptc.com/en/support/article?n=CS241504
/ Constantine
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
