I am configuring HA for Thingworx.
I have installed Zookeeper 3.5.5 and configured Zoo.cfg.Also created myid file.
After that, i am trying to start Zookeeper and unable to start Zookeeper server. I am getting the error. I have attached screenshot what i am getting error.Could you please help on that.
Latha
I've just understood -- your myid has ".txt" extension! Remove this extension, it should be called just "myid", then it will work. Keep double slashes though.
/ Constantine
Hi @vi1.
You might try checking stackoverflow for resolving Zookeeper start up issues. If that doesn't help, you'll need to Google it for other possibilities.
--Sharon
Can you confirm that you have a directory "apache-zookeeper-3.5.5" under c:\zookeeper?
/ Constantine
Yes, I have created folder "apache-zookeeper-3.5.5" under c:\Zookeeper. please find the attached screenshot.
Thank You
And I assume you have complete Zookeeper installation inside this folder? Can you take another screenshot of its content, please?
Thank you.
Here attaching complete folder content screenshot.
Latha
You downloaded Zookeeper's source code instead of the binary distribution. Go back to Downloads and get the one with "-bin" in its name, e.g. "apache-zookeeper-3.5.5-bin.tar.gz".
Thank you for information.
I have downloaded bin folder and copied. Still unable to start the server and getting the errors.
Please refer the attached screenshot.
Vidyullatha
I see on your screenshot an error message, which says that your "conf/zoo.cfg" file is invalid, so I guess you need to take a look at it. Here's explained how to configure it on Linux: https://www.ptc.com/en/support/article?n=CS241504
/ Constantine
I have re verified config file and followed zookeeper configuration document.
still not able to solve.Below are followed in Zookeeper system .
OS: Windows server 2012 R2
1. Installed Java JDK 8
2. Updated java heap size as -Xmx6000m(RAM size is 8GB)
3. Zookeeper deployment 3.5.5-bin
4. Added JAVA_HOME, ZOOKEEPER_HOME path in Environment variable
5. Updated zoo.cfg file and created myid file . Refer the attached screenshots.Also, attached zoo.cfg file.
Could you please help on Zookeeper server issue. I am expecting directory structure issue where i am keeping myid file. I have tried all the possibilities.
Latha
Try to use double slashes in the paths in your zoo.cfg, e.g. "c:\\zookeeper\\data"
/ Constantine
Yes, I have tried . same issue after giving the double slash.
Latha
It's very strange, because I've just tried the same, and it works fine for me -- Zookeeper starts. Maybe try one more thing -- copy this "myid" file into the same "c:\zookeeper\apache-zookeeper-3.5.5-bin\conf" directory, and try this as a zoo.cfg:
tickTime=2000 initLimit=10 syncLimit=5 dataDir=c:\\zookeeper\\apache-zookeeper-3.5.5-bin\\conf clientPort=2181 maxClientCnxns=60 server.1=127.0.0.1:2888:3888 server.2=127.0.0.1:2888:3888 server.3=127.0.0.1:2888:38888
If that doesn't work, then I don't know what to do and would share @slangley suggestion to ask it on some Zookeeper specialized resource or StackOverflow.
/ Constantine
/ Constantine
Thank you for suggestions. Now solved myid file issue after remove the extension.
Thank you very much for helping.
