Thingworx HA
SOLVED
Aquamarine
Aquamarine
Thingworx HA
I am configuring HA for Thingworx.
I have installed Zookeeper 3.5.5 and configured Zoo.cfg.Also created myid file.
After that, i am trying to start Zookeeper and unable to start Zookeeper server. I am getting the error. I have attached screenshot what i am getting error.Could you please help on that.
Latha
1 ACCEPTED SOLUTION
Re: Thingworx HA
I've just understood -- your myid has ".txt" extension! Remove this extension, it should be called just "myid", then it will work. Keep double slashes though.
/ Constantine
15 REPLIES 15
Re: Thingworx HA
Hi @vi1.
You might try checking stackoverflow for resolving Zookeeper start up issues.  If that doesn't help, you'll need to Google it for other possibilities.
--Sharon
Re: Thingworx HA
Can you confirm that you have a directory "apache-zookeeper-3.5.5" under c:\zookeeper?
/ Constantine
Re: Thingworx HA
Yes, I have created folder "apache-zookeeper-3.5.5" under c:\Zookeeper. please find the attached screenshot.
Thank You
Re: Thingworx HA
And I assume you have complete Zookeeper installation inside this folder? Can you take another screenshot of its content, please?
Re: Thingworx HA
Thank you.
Here attaching complete folder content screenshot.
Latha
Re: Thingworx HA
You downloaded Zookeeper's source code instead of the binary distribution. Go back to Downloads and get the one with "-bin" in its name, e.g. "apache-zookeeper-3.5.5-bin.tar.gz".
Re: Thingworx HA
Thank you for information.
I have downloaded bin folder and copied. Still unable to start the server and getting the errors.
Please refer the attached screenshot.
Vidyullatha
Re: Thingworx HA
Also, attached conf folder content screenshot.
Re: Thingworx HA
I see on your screenshot an error message, which says that your "conf/zoo.cfg" file is invalid, so I guess you need to take a look at it. Here's explained how to configure it on Linux: https://www.ptc.com/en/support/article?n=CS241504
/ Constantine
Re: Thingworx HA
I have re verified config file and followed zookeeper configuration document.
still not able to solve.Below are followed in Zookeeper system .
OS: Windows server 2012 R2
1. Installed Java JDK 8
2. Updated java heap size as -Xmx6000m(RAM size is 8GB)
3. Zookeeper deployment 3.5.5-bin
4. Added JAVA_HOME, ZOOKEEPER_HOME path in Environment variable
5. Updated zoo.cfg file and created myid file . Refer the attached screenshots.Also, attached zoo.cfg file.
Could you please help on Zookeeper server issue. I am expecting directory structure issue where i am keeping myid file. I have tried all the possibilities.
Latha
Re: Thingworx HA
Try to use double slashes in the paths in your zoo.cfg, e.g. "c:\\zookeeper\\data"
/ Constantine
Re: Thingworx HA
Yes, I have tried . same issue after giving the double slash.
Latha
Re: Thingworx HA
It's very strange, because I've just tried the same, and it works fine for me -- Zookeeper starts. Maybe try one more thing -- copy this "myid" file into the same "c:\zookeeper\apache-zookeeper-3.5.5-bin\conf" directory, and try this as a zoo.cfg:
tickTime=2000
initLimit=10
syncLimit=5
dataDir=c:\\zookeeper\\apache-zookeeper-3.5.5-bin\\conf
clientPort=2181
maxClientCnxns=60
server.1=127.0.0.1:2888:3888
server.2=127.0.0.1:2888:3888
server.3=127.0.0.1:2888:38888
If that doesn't work, then I don't know what to do and would share @slangley suggestion to ask it on some Zookeeper specialized resource or StackOverflow.
/ Constantine
Re: Thingworx HA
/ Constantine
Re: Thingworx HA
Thank you for suggestions. Now solved myid file issue after remove the extension.
Thank you very much for helping.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
