We are looking into High Availability architecture for Production with Docker Container. The documents says that the docker images are provided for HA. Can you point me where to they are?
Has anyone implemented HA with dockers? Any pointers would be helpful.
thanks,
Preeti
Hi @PreetiGupta.
I noticed you also posted this same reply to a post in our IoT Tech Tips forum. Since that post was from 2018, I am following up with the original author to see if more information can be provided.
--Sharon
Hi @PreetiGupta.
A response has been posted to the original post. Please let us know if you have further questions.
--Sharon
Hello @PreetiGupta,
Just my 2 cents:
/ Constantine
Thanks Constantine.
The information is not documented very well.
I am trying to use these dockers files in dev environment.
Have you stood up Dev using these dockers files?
Preeti
Hi @PreetiGupta.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
