I have a problem when I'm installing Thingworx 8.3 the error message is the next:
2019-09-19 08:55:22.315+0200 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=BRuClCdNTXWVjuFh1RFhU1wmg10AAAAAQUIPAAAAAADyQDhjbUHuRA7LSpV2PP+m; expires=Thu, 17 Sep 2020 08:08:16 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Thu, 17 Sep 2020 08:08:16 GMT
2019-09-19 08:55:22.315+0200 [L: INFO] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] No new License capabilities from license server
2019-09-19 08:55:23.239+0200 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=uE/P/g6nTSqpcpD1VfS4r10mg10AAAAAQUIPAAAAAAAiKa48jQ6KTEcxDhjOemb0; expires=Thu, 17 Sep 2020 08:08:16 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Thu, 17 Sep 2020 08:08:16 GMT
2019-09-19 08:55:23.239+0200 [L: INFO] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] No new License capabilities from license server
2019-09-19 08:55:23.961+0200 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=VppzroINSKysxhQn74oH3V4mg10AAAAAQUIPAAAAAABTdh06Sm2ZjUS8HhMxVxIh; expires=Thu, 17 Sep 2020 08:08:18 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Thu, 17 Sep 2020 08:08:18 GMT
2019-09-19 08:55:23.961+0200 [L: INFO] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] No new License capabilities from license server
2019-09-19 08:55:24.836+0200 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=gdPuXwdPQ0qMxnm4pTa8fF8mg10AAAAAQUIPAAAAAAAkcuaMReYZl+0XUoZLdvtg; expires=Thu, 17 Sep 2020 08:08:16 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Thu, 17 Sep 2020 08:08:16 GMT
Any idea? Could you help me with this?
Thank you in advance
Luis
@ljam You can get the Thingworx.war file from the PTC eSupport portal. please check this article https://www.ptc.com/en/support/article?n=CS305747
These articles might be helpful for you too:
@ljam I just noticed your attached Application logs contains below error
2019-09-19 08:45:22.016+0200 [L: ERROR] [O: c.t.s.s.l.PaidLicenseManager] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Current license is past expiration date. Shutting down the platform!
From the error, it appears that the license for your ThingWorx has expired.
Please refer this article to install the new license.
Vibhuti
Hi @vangne ,
I solved it. The problem was the name of successful_license_capability_response.bin . I rename this file with license_capability_response.bin and now it works but I have thingworx.war of Thingworx 8.3 but the interface is like 8.1. How can I update to the new interface?
Thank you,
--Luis
