Thingworx Mashup Extension - Custom Reports
Manirajan
Hi All,
I am learning Thingworx and its functionalities. Is there any functionalities in Thingworx mashup builder to view custom reports with export options(Refer attached).
Thanks in Advance,
Manirajan
Contact: manirajan729155@gmail.com
5 REPLIES 5
PaiChung
22-Sapphire I
(To:Manirajan)
Within Thingworx you can create mashups to function as your reports
these could be exported as CSV (underlying data) or to PDF using an extension.
If you wanted to use a different program to create the reports.
The underlying data can be accessed through REST API from Thingworx
or you can export it first as CSV for your reporting software.
Manirajan
(To:PaiChung)
I want to view this report in Thingworx Mashup and also i want to export the report.
How do we proceed? Kindly provide more clarifications'
PaiChung
22-Sapphire I
(To:Manirajan)
Depending on what the report should look like, you should be able to create a mashup that represents that information and report.
To then export it.
1. export the data used in the report as CSV, this is something you can do with the Data Export Widget
2. use the export to PDF extension to create a pdf export of that mashup.
mgoel
(To:PaiChung)
Hi @Manirajan
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Otherwise we can digging in the issue more. Do let us know.
Thank you in advance.
Regards-Mohit Goel
Manirajan
(To:mgoel)
Hi All,
I need to create report based on multiple thing properties. This report is one of the portion in mashup. I need to export this report alone to pdf or excel.
Also the report contains chart and table..
is it possible to o this in Thingworx?
Manirajan.V
