Is there any alternative to use instead of repeater widget,to perform the same display/functionality as repeater does?
Is the repeater performance varies with Thingworx version?
I have repeated data to display and used repeater widget but performance wasn't up to the mark as expected.
Note: My repeater rows contains Mashup with custom widgets on it.
Tarun, there has been some performance improvements on repeater widgets in the newer releases. How many rows are you trying to repeat/ replicate? Mimicking a repeater widget behavior without using a repeater widget will increase your bindings and mashup complexity though.
Aanjan, I'm using version 6.5.Are you talking about version releases above that too?
Until nxt release ,you can select ItemLoadBehaviour options config depending on which most suits you
