Is interested about SAP MII (https://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=SAPMII&action=show). Where can i download this extension? Any advice is appreciated. Thanks
Extract:
The composite application SAP Manufacturing Integration and Intelligence (SAP MII) enables adaptive manufacturing processes by synchronizing manufacturing operations with backend business systems. With the ThingWorx SAP MII extension, interact with SAP MII queries and business logic transactions directly from ThingWorx. To use the SAP MII extension, download and import the SAPMII_Extensions.zip into ThingWorx. The package imports the following into ThingWorx: • SAPMII Thing Template • SAPMII Thing Package
The SAP MII extension used to be available for download from PTC Marketplace but it was deprecated and is no longer available. ThingWorx now supports connection with SAP using OData connector named SAPODataConnector – please see documentation http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FComposer%2FIntegrationConnectors%2FConnectorSAPODataPrereqs.html
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi @hkwan.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
