I am using Thingworx trial version and I want to add some properties from my machines to Thingworx.
How can I send data Machine to Thingworx trial?
or I have to install Kepware also please suggest.
Hi @Swapnil_More.
Which trial product are you using? If you are using the hosted product, I don't think you will have the ability to connect your assets.
But you can download one of the 90-day trials which would be installed on your own system that can be configured to ingest data.
--Sharon
You can directly set values in Thingworx model
Thingworx can also receive information directly through
Kepware
Thingworx Agent technology (EMS / Edge SDK)
Connectors (Azure/AWS/PAT)
REST API
Thingworx can pull data through
REST API
JDBC Connection
Extensions (popular one would be some message queue)
If you have Kepware or get the Trial, it is one of the simplest path.
Hi @Swapnil_More.
--Sharon
