While installing the thingworx analytics server 8.0 in local i got the following error(screenshot attached). Is there any workaround for this docker issue?
Hi
This looks similar to the issue reported at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS264269
You should check your version of docker and possibly downgrade it if it is too recent as indicated in the above article.
Christophe
Thank you it worked,
Post installation I am facing another error with the analytics server url and the message is {"errorId":"5dd04fb2-61fc-4652-98ca-7c33862de461","errorMessage":"HTTP 404 Not Found"} .
Hi
Could you post a screenshot of the error showing the URI you access ?
Also can you execute docker logs analytics > analytics.log and upload the analytics.log file created.
Christophe
docker log command gives me an error :
I tried to start the default machine but the host does not exist. Could this be an issue.
I am attaching the install logs as well: https://community.thingworx.com/docs/DOC-3980
