Thingworx dataconnect error
achaube
Hello ,
      I Followed the Dataconnect artice and created a DAD by taking some values from kepserver by creating their respective Thing Template and things .
Also created the datashapes and services which worls fine .
The issue is when i execute the DAD it givess error in dataconnect-worker logs of no enum constant .
Also sometimes it gives error like "transformation has timeseries data but does not have an aggregate transformation applied]" when i apply the timeseries data in datasource .
when i dont it gives the no enum constant error .which doesn't creates the dataset at thingworx analytics builder.
Attaching the dataconnect logs file and my .csv created in thingworx storage
Kind Regards ,
Amar
cmorfin
(To:achaube)
Hi Amar
The error
java.lang.IllegalArgumentException: No enum constant com.coldlight.rest.client.beans.FieldConfiguration.FieldConfigurationDataType.LONG
that you are receiving is because the datatype defined (LONG) is not a valid one for DataConnect.
Valid data types are: Boolean • Integer • Double • String
you will need to change the DAD datashape to use a valid data type to remove this error
Kind regards
Christophe
cmorfin
(To:achaube)
Hi Amar
The error
Kind regards
Christophe
achaube
(To:cmorfin)
Hello Christophe ,
                 Thanks for replying i changed all the properties datatypes to integer from long .now it gives a different error in dataconnect-transform logs shareing the file in the attachment .
Kind Regards ,
Amar
cmorfin
(To:achaube)
Hi Amar
The error I see is this:
java.lang.NumberFormatException: For input string: "40.0"
which would make sense if you changed the data type to integer. 40.0 is not an integer .
You should use double for data type here.
Kind rgeards
Christophe
