I'm trying to perform the first install On thingworx core 8. So far the PostgreSQL database is created and both scripts ran with no problem.
When trying to acess the platform through http://localhost/Thingworx i am only getting a blank page. Them localhost_acess_log on tomcat dysplays:
0:0:0:0:0:0:0:1 - - [21/Jul/2017:11:52:57 -0300] "GET /Thingworx HTTP/1.1" 302 -
0:0:0:0:0:0:0:1 - - [21/Jul/2017:11:52:57 -0300] "GET /Thingworx/Home HTTP/1.1" 401 -
0:0:0:0:0:0:0:1 - - [21/Jul/2017:12:10:32 -0300] "GET /Thingworx HTTP/1.1" 302 -
0:0:0:0:0:0:0:1 - - [21/Jul/2017:12:10:32 -0300] "GET /Thingworx/Home HTTP/1.1" 401 -
0:0:0:0:0:0:0:1 - - [21/Jul/2017:12:17:45 -0300] "GET /Thingworx HTTP/1.1" 302 -
0:0:0:0:0:0:0:1 - - [21/Jul/2017:12:17:45 -0300] "GET /Thingworx/Home HTTP/1.1" 401 -
Believing that this is a 401 error I've tried the recommendations on Frequently Seen Errors upon launching the Thingworx application concerning the 401 error, but with no sucess so far.
I've changed only the password in the JSON file on the Platform.
I am using the following software:
Microsoft Windows 10 Pro 10.0.15063 N/A build 15063
Tomcat 8.5
PostgreSQL 9.4.12
Do you know of any steps I did wrong or missed?
Thank you.
Hello, Marcel.
Did you do this step (from about page 8 of the ThingWorx 8 Install Guide)
http://support.ptc.com/WCMS/files/173115/en/Installing_ThingWorx_8.0_1.1_.pdf
Go to the location of the Tomcat installation and open the server.xml file in the conf folder. For example, C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\server.xml
Replace HTTP/1.1 with protocol="org.apache.coyote.http11.Http11NioProtocol"
Looks like it's still trying to use HTTP/1.1 in your error messages.
-- Craig A.
Hello, Marcel.
-- Craig A.
Hello Craig,
I did it before but my file had syntax errors. I had Tomcat reinstalled to make sure and did the replace command on the service.xml file instead of changing it manually.
I have acess to the platform now. Thank you for the hint!
Marcel.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
