I want to draw a map for a warehouse of our store. in the map i willl show some data (number people in real time, assets data...) .
I have already static image of the indoor map but i want to use a 3d map with dynamic behavior.
I attached an example file for what i want to have as a final result.
I am a newbie in thingworx and i don't know where to start to achieve this purpose.
Any help / suggestion are welcome
Thank you.
This is clearly widget work, which would require at least Javascript knowledge.
You need to create a new widget for ThingWorx and you will find documentation about how to do this at this link.
The best way to create a widget I believe is to make it work in a pure HTML page, for debugging purposes, then when functionally it is done you can add the necessary ThingWorx bits (properties, services, events)
I am not sure if this helps, but give https://www.3dvisualizr.io/downloads a thought. They are a PTC partner (one of the first) and developed this type of widget many years ago, The link to download the plugin is in the page I linked above. There is obviously some pricing involved, but it can be that the pricing outweighs your development cost - up to you.
