I am installing ThingWorx_8.1_1.0 as per the guide.
Here is my setup
OS: Windows 7(this is not present on compatibilty matrix), however is it possible to still run the composer?
Rest of the versions are correct as per the matrix.
I have not configured anything about database, as i assume , the default thingworx war already takes care of it
after pasting the thuingworx.war in webapp
Tomcat gives the following log
07-Feb-2018 12:06:23.507 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars
At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger fo
r a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs d
uring scanning can improve startup time and JSP compilation time.
java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:1012)
at com.thingworx.security.keystore.ThingworxKeyStore.createKeyStorePasswordFile(ThingworxKey
Store.java:102)
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:665)
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:101
6)
at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWorxBootstrapper.java:
74)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4745)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5207)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:952)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1823)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
12:06:24.407 [localhost-startStop-1] ERROR c.t.system.ThingWorxBootstrapper - [message: The system c
annot find the path specified]
at java.io.WinNTFileSystem.createFileExclusively(Native Method) ~[na:1.8.0_111]
at java.io.File.createNewFile(File.java:1012) ~[na:1.8.0_111]
Store.java:102) ~[thingworx-common-8.1.0-b52.jar:na]
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:665) ~[t
hingworx-platform-common-8.1.0-b52.jar:na]
6) ~[thingworx-platform-common-8.1.0-b52.jar:na]
74) ~[thingworx-platform-common-8.1.0-b52.jar:na]
full log is attached
Hi Manasvi.
It is possible to run ThingWorx on Windows 7. The issue you describe can occur if you are installing on a server that was previously running ThingWorx. If that is the case, please check both the User and System environment variables. If you find variables that exist for a previous install, you will need to remove them and restart your system.
If this does not reflect your scenario, please provide additional information and we will be happy to assist further. Which persistence provider are you using? You indicated you had not configured anything in regard to the db. If you're unsure, please provide the name of the ThingWorx file you downloaded as the name will indicate the persistence provider you are using.
Regards.
--Sharon
Hi Manasvi.
Regards.
--Sharon
Hi Sharon,
Deleting Environment variable and restarting the system ,worked; it was indeed because of previous attempts at installation.
And,yes I am using default db (H2) as persistence layer.
Thanks!
So happy to hear that this resolved your issue.
--Regards.
