Thingworx installation
SG_9012314
i'm installing thinworx with postgreSQL for windows. I follow the guide starting from TOMCAT but as soon as i run tomcat.exe no licence file is crated in the folder that i create in the root C:\ThingworxPlatform.
tdixit
(To:SG_9012314)
Hello @SG_9012314
Ideally you shouldn't delete the folders first rather you need to run the uninstaller and that would have automatically delete all the folder
But no issues. Now, first you have to make sure all previous ThingWorx folder, services has been completely deleted. You need to create a new Database again.
Then follow the steps as mentioned in the below guide and let me know if it works or not
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FInstallation%2FThingWorxInstallers.html%23
Toolika Dixit
19 REPLIES 19
tdixit
(To:SG_9012314)
Hi @SG_9012314
Thank you reaching out to PTC.
Could you please help me with below details
  • Please confirm which ThingWorx version are you trying to install
  • Is it a manual installation or through ThingWorx foundation installer
  • If the ThingWorx has been installed. Kindly share the ThingWorx logs present at location <ThingWorxInstallationDirectory>/ThingWorxStorage/Logs and Tomcat logs
Toolika Dixit
SG_9012314
(To:tdixit)
i've tried both; the state of the art is that i cannot finish the installation with the foundation installer because it doesn't fine the correct license.bin
tdixit
(To:SG_9012314)
Hi @SG_9012314
Could you please let me know what all files are present in ThingWorx Platform folder ?
Toolika Dixit
SG_9012314
(To:tdixit)
I cannot attach the file because .bin are not supported. I downloaded and renamed the license file that i downloaded from PTC website with the license management; "license_capability_response". After that i play again the twx-licensing-configurator.exe but license cannotbe found.
thanks
tdixit
(To:SG_9012314)
Hi @SG_9012314
I can see there two license file present in your ThingWorx Platform folder.
Please make sure to keep only once license file in ThingWorx platform folder with name license_capability_response.bin and remove the other bin file which is not getting used from ThingWorx platform folder
And then restart your tomcat and see if it helps to resolve the issue
Toolika Dixit
SG_9012314
(To:tdixit)
i think i solve it.
How do i check if the licence is correctly installed? is there any way to check it directly on twx composer?
thank you,
SG
tdixit
(To:SG_9012314)
Hi @SG_9012314
Yes , you can check it from composer also
Go to Subsystems>Licensing Subsystem > services > GetCurrentLicenseInfo
Execute this service and you will see the details related to your license
Toolika Dixit
SG_9012314
(To:tdixit)
"Unable to Invoke Service GetCurrentLicenseInfo on LicensingSubsystem : No license installed"
tdixit
(To:SG_9012314)
Hi @SG_9012314
can you please attach logs from ThingWorx Storage folder here
Also, share the screenshot of ThingWorx Platform folder
Toolika
SG_9012314
(To:tdixit)
tdixit
(To:SG_9012314)
Hi @SG_9012314
I can see below error in log files
2021-04-15 08:03:51.963+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Unable to acquire ptc_navigate_author_adk_n, error message is Trusted storage hostid does not match system hostid.
2021-04-15 08:03:51.963+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Trusted storage hostid does not match system hostid.
2021-04-15 08:03:51.965+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Unable to acquire ptc_navigate_author_adk_n: Trusted storage hostid does not match system hostid.[Ljava.lang.StackTraceElement;@4b4fb51a
2021-04-15 08:03:51.965+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] ====================================================================
2021-04-15 08:03:51.965+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Unable to acquire license features because Unable to acquire ptc_navigate_author_adk_n: Trusted storage hostid does not match system hostid.[Ljava.lang.StackTraceElement;@4b4fb51a
I believe your ThingWorx platform host Id doesn't match the host id present in your license file.
Can you do one thing  stop the tomcat, remove the license file, generate a new license file from PTC License Management Portal, based on the host Id present in LicenseRequestfile.txt and then place it again in ThingWorx platform folder with name license_capabilty_response.bin and then restart your tomcat
Even after that if the issue persists share the log files again
Toolika Dixit
SG_9012314
(To:tdixit)
I'm so sorry but it's kind complicated... i attached the capture error.
tdixit
(To:SG_9012314)
Please check this article to apply license file. It will have the steps to generate the license file from License Management Portal too
slangley
(To:SG_9012314)
Hi @SG_9012314.
Have you been successful in applying a new license?  If so, please mark the previous response as the Accepted Solution for the benefit of others in the community.
If you are still having issues, please let us know.
Regards.
--Sharon
SG_9012314
(To:slangley)
no i didn't solve.
attached my log file.
tdixit
(To:SG_9012314)
Hi @SG_9012314
I believe earlier you were able to install ThingWorx and the issue was with applying the License file.
Have you uninstalled everything and now again you are doing the installation.
If not, could you please help with the ThingWorx logs present at ThingWorxStorage/Logs directory
Toolika Dixit
SG_9012314
(To:tdixit)
yes i unistall thingworx foundation and i deleted all folders and i tried again. During the installation via thingworx foundation it didn't create folders anymore. After some try with the manual installation of thingworx i was able to find again the folders in my directory but still have errors.  I don't even find thingworx foundation in the  programs to unistall it again.
i can start from scratch but i need your guideline or i'll get crazy with this installation....
thank you for your time,
Simone Guglielmoni
tdixit
(To:SG_9012314)
Hello @SG_9012314
Toolika Dixit
slangley
(To:SG_9012314)
Hi @SG_9012314.
If you have resolved your issue, please mark the appropriate response as the Accepted Solution or post a reply with the solution you found and mark that as the Accepted Solution.  This will help other community members who encounter the same issue.
Regards.
--Sharon
