Thingworx monitor shows every remote thing there is
asmolander
We have a setup that contains one main Thingworx instance and multiple client Thingworx that report different data vie remote things to main Thingworx. I noticed that if you are logged in client Thingworx Composer and check the Monitoring-> Status -> Remote things -> Unbounded it shows list of all remote things there is, eventhough they are on a different Thingworx-machine. How is this possible? How can this be changed so that user can only see the remote things that are on the same machine and what he has rights to.
This is solved, it was error in permission config.
2 REPLIES 2
ttielebein
(To:asmolander)
Can you elaborate a bit about the requirements? Is the user logging in an Administrator? What do you mean by ThingWorx machine? If the remote things are located on another server, but they are pointing to the same ThingWorx server instance, then they will appear here regardless. I am a bit confused about what your issue is
