Thingworx server not connecting
AP_9587236
My thingworx instance was working fine. Suddenly now it shows
"Errors
503 Service Unavailable
Back to Composer".
What to do now?
1 ACCEPTED SOLUTION
This error not occuring after installation. Thingworx was working fine for years, suddenly this error happened. Thanks for your help.
I cleared this error "12:13:21.173 [main] ERROR com.thingworx.system.configuration.PlatformSettings - Configuration setting ContentTypeSettings.supportedMediaEntityContentTypes cannot be null" in logs. Its working now.
So i added this code in platform-settings.json.
"ContentTypeSettings": {
"supportedMediaEntityContentTypes":["image/svg+xml","image/png","image/gif","image/bmp","image/jpeg","application/pdf", "application/json", "image/vnd.microsoft.icon"]
6 REPLIES 6
cmorfin
(To:AP_9587236)
Hi @AP_9587236
You can check the Tomcat and ThingWorx log files to check for errors and possibly restart Tomcat
Hope this helps
Regards
Christophe
Sorry this is not a accepted solution. By mistake i clicked the button.
Btw @cmorfin , i tried restarting tomcat, cleared logs, updated chrome, restarted system, checked platform-setting file, cleared storage space in machine, no other apps are  running. But still thingworx server is not connecting but tomcat is working fine.
I seen error in twdata of pgAdmin. I attached the image. Does that matters?
And I can see these errors in Application logs:-
2021-08-24 15:40:30.229+0530 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] [message: Connections could not be acquired from the underlying database!]
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] [message: Unable to initialize and start system: Connections could not be acquired from the underlying database!]
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] *** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] *** Web Application STATE is being set to ERROR! ***
cmorfin
(To:AP_9587236)
Hi @AP_9587236
Can you upload tomcat and ThingWorx log files ?
regards
Christophe
I attached tomcat logs here. And thingworx logs file exceeds limit. Kindly download from this link.
https://drive.google.com/file/d/1srnivIufO8ukjnDH77MQWL5ACrkvYHv8/view?usp=sharing
cmorfin
(To:AP_9587236)
@AP_9587236
I see from your other post that you identify the root cause, basically ThingWorx cannot connect to Postgres.
The article https://www.ptc.com/en/support/article/CS235937 should help you isolate what is wrong.
regards
Christophe
